01 turn signal issues
i have a 2001 monte carlo ss sometime when you go to use the turn signals they quit working. I found that if you hit the four was switch on the dash and let them flash then the turn signals will start working again. Is this a flasher issue or is it the turn signal switch or the wiring.
fishingpro77
HHR
August 4th, 2016 12:44 AM
RomanGuzi
October 2nd, 2011 11:40 AM
