Platform: A-, G-, & W-body
01 turn signal issues
Old Apr 29, 2010 | 5:32 PM
1968ss's Avatar
Default 01 turn signal issues
i have a 2001 monte carlo ss sometime when you go to use the turn signals they quit working. I found that if you hit the four was switch on the dash and let them flash then the turn signals will start working again. Is this a flasher issue or is it the turn signal switch or the wiring.
Old May 21, 2010 | 10:24 PM
bsr2002's Avatar
Did you try changing out the flasher? They are the cheapest.
Old Jun 25, 2010 | 6:14 AM
grignard_reagent's Avatar
yep
i woould suggest the same
try changing the flasher
thats indeed the cheapest
else you can try fiddling with the switcher
and find it for yourself
fishingpro77
HHR
Aug 4, 2016 12:44 AM
RomanGuzi
Oct 2, 2011 11:40 AM
92Nautiquesnob
Oct 6, 2009 12:26 PM
Mute617
Nov 24, 2008 6:16 AM
