Platform: A-, G-, & W-body
06 Monte Carlo LT key stuck in ignition, car won't start, trunk won't open, windows w
Old Aug 6, 2021 | 5:39 AM
2phat's Avatar
Default 06 Monte Carlo LT key stuck in ignition, car won't start, trunk won't open, windows w
My daughter took her car to target the other day. Parked went shopping and came back to the car not starting. They thought the battery was dead. After daughter and wife trying whatever they could find in YouTube they gave up.. here's what I noticed now. The key is technically stuck in the ignition although they pulled it out. But it's not in the lock position. They had to by pass the center console to put car in neutral because the car is not showing any brake lights also or normally you can push the brake to put the car in gear.. nothing. Also notice that the windows won't roll down and the button on the dash for the trunk are not working. Checked all the fuses there good. The battery has good voltage but at first wasn't very tight. I have very limited time because I work so much so any help with these key problems that might ring a bell in all open ears.. thank you. Being a new member on here you can text me your thoughts or answers. 9038122239
bankshots
Oct 3, 2022 5:32 PM
Michelle709902
May 13, 2019 1:47 AM
Gjackson5
Jun 29, 2017 7:35 AM
ProMtcy
Jun 26, 2017 10:21 PM
bankshots
Traverse
Apr 25, 2010 4:31 PM
