car dead and key stuck in ignition
Old Apr 25, 2010 | 6:13 PM
bankshots's Avatar
Default car dead and key stuck in ignition
My traverse has been acting up a couple of days by running after the car is turned off and the key taken out. If you put the key back in and "restart" and shut off it went off and a fan ran for a couple of minutes and shut off. I was planning on taking to the dealer monday morning but I went to the garage today and the car is completely dead and I cant remove the key from the ignition. It wont turn back far enough to where you normally remove the key. Unfortunately the car is parked under cabinetry which will not allow me to open the hood to jump the vehicle and the car will not shift out of park to push the car back. Any suggestions?
Old Apr 25, 2010 | 7:13 PM
nauticstar87's Avatar
You can't turn the key to the on position, press the brake and put it in neutral? Just want to be sure I'm reading it correctly.
Old Apr 25, 2010 | 10:32 PM
bankshots's Avatar
Default key turns on, car dead and cant remove key
I can turn the key to the on position but absolutely no power is evident. You can not turn the key all the way off to release the key. In no position while braking can the car be taken out of park.
Old Apr 26, 2010 | 12:25 AM
therewolf's Avatar
Hi bankshots,
Welcome to the Chevy Forums.
Does it have a console-shift automatic transmission? My daughter just had the same problem this weekend. It's a dead Transmission Interlock Security Solenoid.
What I did was ( leave the key in the ignition) jump start the car. I took it to my mechanic.
They pulled out the solenoid, it's a dealer part which serves no practical purpose whatsoever. I have absolutely no intention of spending hundreds of dollars to have the dealer put in a new one. Hopefully, your battery will also charge and still be OK.
Old Apr 26, 2010 | 5:49 AM
bankshots's Avatar
Thanks for the info, would love to jump it but I cant back it up to open the hood. We have cabinetry installed on the back wall of the garage and the traverse pulls in just under it so I can't open the hood. Can a tow truck literally just pull the vehicle back about a foot without being in neutral since I can't take it out of park? Wouldn't this part be covered under warranty to be taken to the dealer.
Thanks for your help.
Old Apr 26, 2010 | 7:51 AM
EvansBlue's Avatar
You can drag it yes, but the wheels will be locked up.
A similar thing happened to my mom's Envoy. Her battery failed at a gas station and when she went to start her car back up, it wouldn't respond. She couldn't get the key out of the ignition either because of the key lock. Luckily we were able to get under the hood. You should be able to hook to it with either a towtruck, or you can find a suitable underbody member that you can hook to a truck and drag it out.
Old Apr 26, 2010 | 8:00 AM
therewolf's Avatar
If the key will go to the "start" position, you may be able to shift it into neutral, then roll it backwards..
For what a tow truck's going to charge, you could buy a good jump-box.(I did.)
Old Dec 22, 2014 | 6:37 PM
icecold45's Avatar
Default ignition issue
I can turn the key to the on position but absolutely no power is evident. You can not turn the key all the way off to release the key. In no position while braking can the car be taken out of park.[/QUOTE]
Old Dec 22, 2014 | 6:38 PM
icecold45's Avatar
Car dead and keys stuck in ignition. How do I get them out?
Old Dec 22, 2014 | 8:45 PM
Welcome to the forum
What is the vehicle, year and model ?
Is the battery completely dead?
Is the vehicle able to be shifted from gear range and back to park?
