Platform: A-, G-, & W-body
1997 lumina help asap
Old Oct 23, 2019 | 10:39 PM
Northern Starr's Avatar
Default 1997 lumina help asap
Just got a 97 lumina. $100 with new tires. No key. And it needs a new column.....
So to fix both issues can I get a junk yard column with key and the tdm from the same car?
Or better yet just remove vats or disable it?
Old Oct 24, 2019 | 11:28 PM
kevinkpk's Avatar
Good luck with VATs removal. You can replace the column, and relearn the BCM with whatever key you want.
Old Oct 24, 2019 | 11:31 PM
kevinkpk's Avatar
This what I would do, replace the column, and ignition switch. The new switch should come with a key without the pellet. Have a key made that is cut for the switch with a pellet key, and relearn the BCM, SHOULD be as easy as with key switch on, no crank for 20 minutes, then without tyurning ignition off, just go to start.
Old Nov 15, 2019 | 4:04 AM
Megaglow_z's Avatar
Not sure when you swap the column but I did this to my 99 lumina over the weekend.
Old Jan 23, 2022 | 10:51 AM
Michale's Avatar
If you would have asked me, that what we should then I would invest that $100 to an online website to make it double for the lifetime earning within few gaming session. which is an available casino. you can read there by brexit pros and cons to understand it better logic and learn the gaming strategy.
fgolds
Apr 8, 2017 6:16 PM
sircrunch
Feb 7, 2012 9:26 AM
EdsLumina97
Aug 8, 2010 7:03 PM
Jasons1990lumina
Feb 23, 2006 1:26 PM
