Platform: A-, G-, & W-body
1999 Lumina Where is the Horn
Old August 8th, 2010 | 5:19 PM
t1mvv's Avatar
Default 1999 Lumina Where is the Horn
Horn isn't working and i need to fix it before inspection. Fuse looks good. After giving a quick look I can't seem to locate the horn. Anyone know where it's located under thee hood? THANKS
Old August 9th, 2010 | 3:30 PM
rkuelbs's Avatar
The horn on your car is located below the right side headlamp. Before replacing, I would test for power to the horns. Since there are actually 2 horns, it is more likely that the horn relay or horn contacts have failed, losing power to both horns. The horn relay is located in the electrical center on the driver's side under the hood.
Warteetee
December 22nd, 2013 9:48 AM
sabres07
August 20th, 2009 9:46 PM
isaac_22
December 26th, 2007 10:23 PM
zulu
March 28th, 2007 5:58 AM
MagicElectric
February 27th, 2007 4:42 PM
Quick Reply: 1999 Lumina Where is the Horn
