Platform: A-, G-, & W-body
1999 Lumina Where is the Horn
Old Aug 8, 2010 | 4:19 PM
t1mvv's Avatar
Default 1999 Lumina Where is the Horn
Horn isn't working and i need to fix it before inspection. Fuse looks good. After giving a quick look I can't seem to locate the horn. Anyone know where it's located under thee hood? THANKS
Old Aug 9, 2010 | 2:30 PM
rkuelbs's Avatar
The horn on your car is located below the right side headlamp. Before replacing, I would test for power to the horns. Since there are actually 2 horns, it is more likely that the horn relay or horn contacts have failed, losing power to both horns. The horn relay is located in the electrical center on the driver's side under the hood.
Warteetee
Dec 22, 2013 8:48 AM
sabres07
Aug 20, 2009 8:46 PM
isaac_22
Dec 26, 2007 9:23 PM
zulu
Mar 28, 2007 4:58 AM
MagicElectric
Feb 27, 2007 3:42 PM
