1999 Monte Carlo Antifreeze leak
My 1999 Z34 has developed an antifreeze leak. The valve cover gasket was replaced two years ago and the water pump about three.
Steam begins coming from the passenger's side, a puddle is building under the main pully, and obviously it smells of burning antifreeze.
I've looked around the water pump and don't see any obvious leaks, also nothing appears to be coming from the intake manifold. Someone told me these cars have a 'thermal bypass', however, I don't know what this does or the routing.
Can someone tell me how the coolant system flows through the car? Obviously I'm aware of the two radiator hoses, water pump, and I can somewhat see the heater core hoses. Besides that, what other pipes or hoses exist that may cause this leak?
Thank you,
Peter
Thank you,
Peter
Thank you,
Peter
Thank you,
Peter
if its steam then its more than likely coming from your radiator. i have a 99 lumina and i replaced my intake gasket about a year ago. the pressure created from the faulty gasket made a hairline crack in the side of my radiator causing massive amounts of steam after running my car for about 15-20 mins.... check the sides of your radiator look for dry white spots along small lines. I hope this helps.
05MonteSS
Jan 16, 2013 4:41 PM
capsnumber1
Oct 2, 2009 8:59 AM
