Platform: A-, G-, & W-body
2002 Monte Carlo SS Tranny Issues
Old May 8, 2020 | 11:07 PM
Dana Rae DeNio's Avatar
Default 2002 Monte Carlo SS Tranny Issues
I bought a 2002 monte carlo ss with 156k miles. Needed power steering pump. Giy said it sat for a year. I drove it and it shifted fine...got it home changed power steering pump and went to drive it and tranny started acting up...also noticed that i have a broken motor mount and im wondering if maybe the engine is sitting on tranny lines and pinching them off...temperature is running over 1/2 way point could this be the issue...there are no leaks.
Old Jan 2, 2021 | 9:43 PM
chevyboy@22's Avatar
unfortunately it sounds like you need an overhaul. once they get to this point there isn't really anything you can add or do to it to extend its life - sorry for the bad news
Old Apr 13, 2021 | 5:10 PM
Dartman's Avatar
Default Acting up trans
Hello so those transmissions are notorious for sticking valves and solenoids . If theres crud in the pan your sunk . Since it drove home fine if theres no crud in the pan a rebuilt valve body recommend do the shift kit and new solenoids should have it cruzing in style in no time.
sanchezmar
May 27, 2011 1:04 PM
yankees2351
Apr 8, 2011 5:58 PM
IsaiahGmaz
Sep 1, 2010 8:30 PM
