Platform: A-, G-, & W-body
2007 monte carlo stuck in park
Old Sep 12, 2008 | 9:56 PM
jetplanejay's Avatar
Default 2007 monte carlo stuck in park
its parked on a slight angle on a downslope. the button is stuck on the shifter. all fuses are good.
anybody got any idea what i can do?
Old Sep 13, 2008 | 5:59 PM
twizzle12's Avatar
Default RE: 2007 monte carlo stuck in park
Torque Lock
If you are parking on a hill and you do not shift your
transaxle into PARK (P) properly, the weight of the
vehicle may put too much force on the parking pawl in
the transaxle. You may find it difficult to pull the shift
lever out of PARK (P). This is called torque lock.
To prevent torque lock, set the parking brake and then
shift into PARK (P) properly before you leave the
driver’s seat. To find out how, see
Shifting Into Park (P)
on page 2-26
When you are ready to drive, move the shift lever out of
PARK (P)
before you release the parking brake.
If torque lock does occur, you may need to have another
vehicle push your vehicle a little uphill to take some of
the pressure from the parking pawl in the transaxle,
so you can pull the shift lever out of PARK (P).
Shifting Out of Park (P)
Your vehicle has an automatic transaxle shift lock
control system. You must fully apply your regular brakes
before you can shift from PARK (P) when the ignition
is in RUN. See
Automatic Transaxle Operation on
page 2-22
If you cannot shift out of PARK (P), ease pressure on
the shift lever by pushing it all the way into PARK (P)
while keeping the brake pedal pushed down. Release
the shift lever button if you have a console shift.
Then move the shift lever out of PARK (P), being sure
to press the shift lever button if you have a console shift.
If you ever hold the brake pedal down but still cannot
shift out of PARK (P), try this:
1. Turn the ignition key to ACCESSORY.
2. Apply and hold the brake pedal down until the end
of Step 4.
3. Shift to NEUTRAL (N).
4. Start the engine and shift to the drive gear
you want.
5. Have the vehicle fixed as soon as you can.
Old Mar 12, 2023 | 4:09 PM
Alaskanboy1968's Avatar
Default My 2007 monte carlogoes into all gears just fine but won't key won't go into off pos
Help I can't get my mo te to turn off stuck in acc run or on won't go into off position why,?
Old Aug 30, 2023 | 2:43 AM
jimtmcdaniels's Avatar
See discussions posts on the shifter interlock switch problems.
The car thinks you don't have it in park. A safety feature.
suburbansr4me
Dec 25, 2018 8:03 AM
shreyajo
Apr 9, 2018 9:01 PM
DaveK
Mar 7, 2013 11:44 PM
bales_park
Feb 8, 2011 7:26 PM
karmazero
Oct 18, 2008 10:34 AM
