91 Lumina Stalls & Won't Start
#11
Lumina won't start when hot
From responses I have received, Coil pack and crank shaft sensor most probable cause. Mechanic will run through a number of standard tests. Might show up something
#12
97 Lumina won't start when hot -Possible cause
When car won't start, PCM scanner shows "No Communication" message. Also fuel pump does not hum when ignition switched turned on. My guess is defective PCM. Does this make sense. Should I change PCM?
Brint
Brint
#13
97 Lumina Hot start problem solved
Problem was resolved by changing computer. When Lumina would not start, computer would not communicate with OBD scanner. Also wiring diagram shows fuel pump relay controlled by output from computer only. Only mystery is how engine runs ok once started even though computer has failed. What conrols the fuel pump?
pharcydeabc
10
January 4th, 2024 8:32 PM
johns2001tracker2.0
February 4th, 2014 10:19 PM
PrairieTruck
April 6th, 2012 9:53 PM
