Platform: A-, G-, & W-body
93 Lumina Z34 Possible Fuel Problem
Old Mar 23, 2011 | 9:10 PM
msp0088's Avatar
Default 93 Lumina Z34 Possible Fuel Problem
i have a 1993 chevy lumina z34. the problem is the car starts up and drives, but when i try and go over around say 4000rpms it stalls out and doesn't start for a few minutes or more. i have fuel in the tank, i put fuel system cleaner in, i checked the fuel pump relay and it clicks when i turn on the power, the fuel pump fuse is good, i cleaned the idle air control value to see if that was the problem but none of that seems to work. the only other thing left i can think of is the fuel pump is bad. Is there any other opinions of what may be wrong?
Thanks.
Old Nov 26, 2019 | 6:49 PM
Rick Beem's Avatar
I was having like symptoms with my LQ1 engine. It was due to a flaky throttle position sensor (TPS.)
RLwiley87
13
Sep 18, 2019 11:27 PM
Skunked again
Mar 16, 2016 7:16 PM
mikeatpriestlake
11
Apr 11, 2014 10:00 PM
msp0088
Apr 24, 2011 6:40 PM
JMelick
Apr 2, 2010 3:39 PM
