Platform: A-, G-, & W-body
97 Lumina stallls out
Old Sep 13, 2010 | 5:28 PM
cofused chev owner's Avatar
Unhappy 97 Lumina stallls out
I have a 97 Lumina that will run smooth an silk while sitting and Idling,and it will usually run good first thing in the morning, but if you cut if off and then try start it and take off it will jump and skip and backfire. The problem is it doesn't do it all the time and some time are worse than others. I have replaced the cam sensor, the egr sensor, the plugs and wires. It is not throwing any codes when it is acting up, but it sure does smell. Could not even get it home the other night it completly shut off, but would start just fine, but would skip and jump when I accelerated. Any clues??
Old Oct 31, 2010 | 11:14 AM
fifthstring27030's Avatar
I have a 1998 doing exactly the same thing. Have taken it to shop several times, they cannot find the problem they have repleced several things and ran up $800 in repairs but car still does it. It sounds like it is running out of time when you accelerate but idles just fine. It also does it intermittedly. Have you had any luck with yours ?
Old Apr 25, 2011 | 3:40 PM
no luck so far, cleaned the coil post and car ran great for about 7 months and now it started jumping and skiping again. We replaced the coils, all 3 and it stills does it. everyone is total baffled, think may it may be the converter, not sure. Any luck with yours?
chevy_smoken
May 18, 2010 7:02 PM
tonym2180
Feb 21, 2010 3:37 PM
85_impala
Feb 2, 2010 12:45 PM
Robert Castellow
Jul 31, 2009 12:55 PM
MagicElectric
Feb 27, 2007 3:42 PM
