Platform: A-, G-, & W-body
97 Monte Carlo Won't Start. NEED HELP PLEASE!
Old Aug 17, 2010 | 7:30 AM
mark_b10's Avatar
Default 97 Monte Carlo Won't Start. NEED HELP PLEASE!
I have a 97 Monte Carlo, 3.1L and it decided to not start back up after lunch yesterday when I was attempting to go back to work... Even after adding some gas to make sure I didn't somehow run out of gas, it still wouldn't start. When i turn the ignition, it rolls over but doesn't seem to ignite any fuel. First thing first, I checked to make sure I was getting a spark, and I was. So I'm guessing a fuel issue? Next, I checked the fuel pump. I was told that the fuel pump should turn on for about 10 seconds after turning the key to accessory, and if I could hear it turn on, the fuel pump should be in running condition. Surely enough, I could hear the humming of the fuel pump when I turned the key. From there, I'm stuck. I was told that it may be a fuel injector that went out and possibly caused the others to stop running as well. Looking for any advice on what to check next or any possible solutions! Thanks!
phillipsj
Mar 11, 2011 12:48 AM
colliez28
Feb 1, 2011 12:13 PM
montecarlotory
May 15, 2010 9:31 PM
Fritz823
Aug 12, 2009 3:43 PM
KATMAC
Feb 17, 2009 9:37 PM
