Platform: A-, G-, & W-body
98 Monte - Codes pertaining to Shifting ( Sluggish Acceleration from Stop ) )
Old Apr 3, 2012 | 12:41 PM
donorlow's Avatar
Default 98 Monte - Codes pertaining to Shifting ( Sluggish Acceleration from Stop ) )
My 1998 Monte Carlo has been driving fine for years and all of a sudden My SES light popped on and I realized something was wrong when I would be accelerating from a dead stop.. It is like I am in stuck 2nd or 3rd gear. I read my codes and this is what I had.
P0740 - Torque Converter Clutch Circuit
P0753 - Shift Solenoid A Electrical
P0758 - Shift Solenoid B Electrical
P1860 - TCC PWM Solenoid Circuit
I have done multiple searches, but I have had no luck. I am getting multiple hits regarding Chevy Trucks and how replacing the ignition switch may resolve this issue since the circuitry goes through the ignition. Just no luck for a Monte Carlo.
My Question: If this is the same symptoms and replacing the switch will resolve the issue, Should I replace the lock tumbler/Ignition Switch or the Ignition Switch Feed Circuit?
If not and there is another possible solution to this issue, what could it possibly be?
Thanks in advance...
Old Apr 3, 2012 | 8:53 PM
donorlow's Avatar
I replaced the Ignition Feed Circuit and the issue still remains. Just an FYI.. Any Ideas?
Old Apr 4, 2012 | 11:27 AM
EinST's Avatar
Make sure the TRANS fuse in the underhood fuse block isn't blown and check the voltage at that fuse with key ON. It should read battery voltage. That fuse supplies the power to the solenoids inside the transaxle over the PNK wire.
Old Apr 5, 2012 | 3:31 PM
donorlow's Avatar
The fuse was blown, we replaced it and were able to drive it around the block without any issue.
2 hours later and we started the car and the fuse popped again. I took the car over to AAMCO at this point cause I cant figure it out.
They pulled the car in and looked it over for a a few minutes. The diagnosis is that one of the Solenoids is causing a dead short and it has to be replaced. Oh well, this is where I make a exit stage left and let someone drop the tranny and do the work.. It is just a little to much for me at this point..
Old Apr 5, 2012 | 5:25 PM
EinST's Avatar
It's not as bad as you make it sound. They just need to drop the pan, not the whole transmission. Hope they nailed the diagnosis.
Old Apr 6, 2012 | 5:44 PM
donorlow's Avatar
Yeah they nailed it.. It was one of the solenoids.
Old Jul 11, 2012 | 11:14 AM
dad's Avatar
dad
Having same problem with 1997 chevy truck. Is there a way to check the electrical on the selionoids without dropping pan?? Could this be the same with my truck?? Thanks Dad
kansfan48
Jun 5, 2013 9:54 PM
JoeJr
May 26, 2011 3:54 PM
First Chevy Truck
Feb 10, 2011 12:21 PM
naamatis
Mar 11, 2010 10:36 PM
my2kidsmake4
Dec 12, 2008 2:24 PM
