Platform: A-, G-, & W-body
ABS Module?
Old Nov 29, 2018 | 1:45 AM
07SSman's Avatar
Banned
Default ABS Module?
I had the following messages pop up in the DIC today, in rapid succession:
SERVICE BRAKE SYSTEM
SERVICE BRAKE ASSIST
SERVICE TRACTION CONTROL
This comes and goes while driving, and resets with every key cycle. The only performance difference is that I have no cruise control. Is this, as I believe, the ABS module? If so, how hard is it to replace?
2007 Monte Carlo SS, 188K miles, LS4 engine, 4T65E-HD transmission, no significant mods
Old Dec 7, 2018 | 12:30 PM
SBchevyfan's Avatar
Did the Brake warning lamp come on at the same time?
Old Dec 7, 2018 | 3:34 PM
07SSman's Avatar
Banned
Yes, as well as the traction control light. Thought I said that.
Old Dec 8, 2018 | 8:11 AM
SBchevyfan's Avatar
Have you checked the brake fluid in the master cylinder. There is a sensor there that can trip those warnings if the fluid level gets too low.
Old Dec 16, 2018 | 12:21 PM
07SSman's Avatar
Banned
Well, I topped it of as best I could (if there's a min marker, I can't find it, so I went just under the max) last Tuesday, and the problem has not reoccurred. Thanks a lot!
