any help would be appreciated on a 91 lumina 3.1
ok i bought the lumina and had no heat at all nothing worked so i started with the heater resistor then moved over to the blower motor then still cold replaced the thermostat which was stuck open then bled it works good on defrost but blows lil warm air if none at all through vents or down below defrosts car very quickly but no heat through vents or bottom any help would be greatly appreciated steven
ps.ind of new to chevys thamks again
Are you saying it blows cold air through all the vents or doesn't blow any air at all. If it only blows cold air it could be a clogged heater core as stated. Check the hoses going into the heater at the firewall. If both are equally hot then the core is not clogged. If one is hotter than the other then it is clogged. If the heater core is good then you need a blend door actuator.
MadeyeX
January 15th, 2013 9:30 AM
bluemonstr
October 6th, 2012 8:35 AM
kywill
December 17th, 2011 8:44 AM
jnc0730
November 14th, 2011 8:33 PM
JonxSmith
September 8th, 2011 10:29 PM
