Platform: A-, G-, & W-body
any help would be appreciated on a 91 lumina 3.1
Old Mar 7, 2014 | 1:48 PM
rockfan12100's Avatar
Unhappy any help would be appreciated on a 91 lumina 3.1
ok i bought the lumina and had no heat at all nothing worked so i started with the heater resistor then moved over to the blower motor then still cold replaced the thermostat which was stuck open then bled it works good on defrost but blows lil warm air if none at all through vents or down below defrosts car very quickly but no heat through vents or bottom any help would be greatly appreciated steven
ps.ind of new to chevys thamks again
Old Mar 12, 2014 | 10:27 PM
sledge.impy's Avatar
is the heater core plugged up or something or else something or else none at all or does the car have ac and there is oil from the ac which has leaked on the ac thingy on the firewall and blocking air flow does it have strong air flow or is it weak is this r12 or r134a or who knows can you answer this.
Old Mar 13, 2014 | 11:31 AM
Are you saying it blows cold air through all the vents or doesn't blow any air at all. If it only blows cold air it could be a clogged heater core as stated. Check the hoses going into the heater at the firewall. If both are equally hot then the core is not clogged. If one is hotter than the other then it is clogged. If the heater core is good then you need a blend door actuator.
Old Mar 14, 2014 | 10:28 AM
it blows warm air through the defroster on the windshield and defrosts very well when you go to switch it doesnt do anything no air flow at all it doesnt blow through the vents
Old Mar 14, 2014 | 10:45 AM
When you set it to blow through the vents, does it stop blowing through the defrost?
Old Mar 14, 2014 | 1:37 PM
Unhappy
yes it does
MadeyeX
Jan 15, 2013 8:30 AM
bluemonstr
Oct 6, 2012 7:35 AM
jnc0730
Nov 14, 2011 7:33 PM
JonxSmith
Sep 8, 2011 9:29 PM
