BCM fuse for 1997 Monte
Hi,
A couple of days ago I bought a used 1997 Monte Carlo. The remote is not working and I can’t get to lock and unlock the doors. I found this post where it say to remove the BCM PRGRM fuse then reprogram the remote. I can’t find any fuse labeled BCM . In the manual is one labeled for Power locks-door lock relay, keyless entry receiver and another one for I/P ELECTRONICS IGNITION FEED …keyless entry receiver. Is one of these the BCM fuse?
thanks
thanks
Heck it might be. Take it out, test it, and put it back in. Have you tried replacing the battery in the handheld remote unit?..........Tom
ill4na8na2
April 7th, 2024 6:50 PM
2001Suburban
August 3rd, 2015 11:28 AM
d1nonly34
December 10th, 2008 10:05 AM
