Platform: A-, G-, & W-body
DRLs on '99 Monte
Old Oct 15, 2008 | 7:13 AM
saunders1313's Avatar
Default DRLs on '99 Monte
Does anyone know how to disable the DRLs on a Monte without engaging the parking brake?
Old Oct 15, 2008 | 7:23 PM
shawnvw's Avatar
Banned
Default RE: DRLs on '99 Monte
find the drl module(behind left side of dash, on electronic brake control modle bracket), there will be 2 connectors. The one you need is a 7 pin harness. wire colors are as follows:
A brown
B lt blue
C dk grn\pnk
D yellow
E dk blue
F dk grn
G black
Cut the dk blue wire from the module, and attach it to the black wire. The dk blue wire is the output from the drl module, but at the same time it is also the ground to one of the highbeams. So if you just cut the wire, one high beam will not work, so you must attached it to ground.
Mommy2threeboys
Uplander
Dec 28, 2010 8:04 AM
guttervamp
Feb 7, 2010 10:32 AM
98tahoe
Dec 1, 2007 1:18 PM
GMz71
Sep 28, 2007 11:22 PM
spydrz
Apr 12, 2007 12:29 AM
