Platform: A-, G-, & W-body
Electrical Mystery
Old Mar 13, 2018 | 10:09 PM
07SSman's Avatar
Banned
Default Electrical Mystery
I have a 2007 Monte Carlo that is driving me insane. I've replaced the battery cables, the battery, and the alternator, and it still says "check battery charging system" and only drives about a block before dying.
The guy who towed it said it could be a bad ground, but every place he named as a possible location for a ground (alternator to bracket, engine to subframe) is not a place where a gap could magically appear.
Does anyone have any other ideas?
Old Mar 14, 2018 | 3:41 PM
kevinkpk's Avatar
You really need a voltmeter for this. Actually check with engine running if the alternator is putting out over static (before starting) battery voltage. If you are in doubt of a ground or lack off, you can add an additional ground cable from the battery to the block, or frame.
