Lumina Spmetimes Won't Start
This started a couple of weeks ago. I scanned thru forums and googled this and it seems like this happens with GM cars 10 years and older. I replaced the battery and the problem went away for about a week.
I was leaving the grocery store today when the security light stayed on. I waited about 10 min till the light went off. turned the key and it engaged. Will changing out the lock cylinder do the trick? Or do I need to do that VATS Bypass thing?
Things I've already done:
1. Battery cables ok
2. New Battery
3. Alternator checked out ok at Autozone <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
2. New Battery
