Platform: A-, G-, & W-body
Radiator Drain Plug Removal - 1998 Lumina
Old Jul 25, 2011 | 12:47 PM
csbacct's Avatar
Default Radiator Drain Plug Removal - 1998 Lumina
To avoid damaging the radiator itself, could someone tell me how to safely remove the drain plug from the radiator in a 1998 Lumina?
Thanks,
Craig
Old Jul 25, 2011 | 4:18 PM
kevinkpk's Avatar
Thanks,
Craig
if you are wanting to drain the radiator, pull the bottom hose.
Old Jul 26, 2011 | 5:42 PM
csbacct's Avatar
Hi Kevin,
Thanks for the comeback. I'm not looking to drain the radiator per say; I want to change out the drain plug. The drain plug that is in the radiator has been damaged, the thumb grip has been ripped off, probably with a pair of pliers. I've already got the new one, just can't get the old one out.
Craig
Old Jul 26, 2011 | 5:50 PM
kevinkpk's Avatar
Hi Kevin,
Craig
If it is damaged, You prbably will need vise gripes to get it out. If it is not leaking, I'd suggest leave it alone, and when you need to drain the radiator, pull the hose.
Old Jul 26, 2011 | 6:59 PM
EinST's Avatar
The radiator drain petcock in those years was a push-in twist lock kind. Twist it about a quarter turn counterclockwise and pull to remove:
domano 68
Jan 24, 2014 7:26 PM
JK23112
Mar 21, 2010 3:12 PM
TomS209
Oct 6, 2009 2:13 PM
julian734
Astro
Mar 29, 2008 12:35 AM
peterz
Apr 22, 2007 8:05 PM
