Platform: A-, G-, & W-body
rough idle 3 dead cylinders. 2,4 and 5 cylinder
Old Aug 8, 2013 | 10:09 PM
hufflumi's Avatar
New User
Awaiting E-mail Confirmation
Default rough idle 3 dead cylinders. 2,4 and 5 cylinder
hi everyone I'm new to this forum and looking for some help with my 99 Lumina with 3.1 engine. issue that I'm having is that I have a extremely rough idle. I don't have any misfire codes but just a EGR Valve open code. in order to keep the engine running I have to unplug the MAF sensor. I checked to see if I had any dead cylinders and I'm getting spark on all the cylinders. when I unplugged 1,3 and 6 engine died out. cylinders 2,4 and 5 had no affect when unplugged. but like a said I have spark on all the cylinders. I also have the oil pressure switch light on that come on when this all started. I replaced the crankshaft sensor no difference. thanks for any insight.
Old Sep 23, 2013 | 12:15 PM
WyrTwister's Avatar
First , find out what is going on with the oil lite ? If you really do not have oil , the rest does not matter .
I would check the oil level & then either change the oil & filter , or at least change the filter & top off the oil . ( Is the oil filter stopped up or defective ? )
See if the oil pressure sensor & wiring ( including connector ) is OK .
Did you hear any knocking , clicking or tapping ( lifters ) ?
You get these straightened out , come back with an update .
God bless
Wyr
macmommy
Apr 22, 2020 1:23 PM
Dads Toy
Nov 28, 2011 12:22 PM
MCF34
Nov 13, 2007 4:04 PM
