Platform: A-, G-, & W-body
Tachometer installation
Old Nov 5, 2009 | 8:52 PM
Duramax_Dude87's Avatar
Default Tachometer installation
I need info from anyone that can help. I am trying to install a Tachometer in to my 97 Lumina and i dont know where to hook up the tach wire at. i know where to hook up the vast amounts of other wires that come with the gauge but im just at a lose for this one. Any help is appreciated.
Patrick
Old Feb 2, 2010 | 12:47 PM
94 lumina's Avatar
idk much about the newer ones but if it still has a distributor then there should be a lead off of there for a tach.....
Old Feb 19, 2010 | 1:35 AM
The Saint's Avatar
Chevrolet Lumina 97
TACHOMETER WIRE PURPLE/WHITE or WHITE Ignition coil
Old Feb 19, 2010 | 1:47 AM
The Saint's Avatar
To find a tachometer wire with a multi-meter:
1. Set meter to AC voltage.
2. Attach the (-) probe of the meter to chassis ground.
3. Start and run the vehicle
4. Probe the wire suspected of being the tachometer wire with the other probe.
5. If this is the correct wire, the meter will read between 1V and 6V. This wire will increase in voltage as the RPMs are increased.
See you.
dmoore
Dec 7, 2011 9:02 PM
fdxdoeboy
Nov 16, 2007 11:12 PM
shulamite
Nov 12, 2007 3:41 AM
Rivernut
Nov 1, 2007 7:14 AM
96beretta142k
Sep 27, 2006 3:20 PM
