Troubleshooting 2000 Chevy Lumina with
Hello,
I've been trying to troubleshoot the engine on my 2000 Chevy Lumina for a while now. We started out with error codes refrencing the PCV and EGR Valves and after replaceing both of those and replacing the PCV Valve's tube I am still getting error codes. Still related to the EGR valve and it seems to be causing a cylinder misfire. Any thoughts? Below are the most recent codes:
Details:Date: 08/13/2014
Code: P0305
Explanation: Cylinder 5 Misfire Detected
Date: 08/13/2014
Code: P1404
Explanation: EGR Closed Position Error (1997)
Date: 08/13/2014
Code: P0404
Explanation: "EGR ""A"" Control Circuit Range/Performance"
Date: 08/13/2014
Code: P0341
Explanation: "Camshaft Position Sensor ""A"" Circuit Range/Performance"
Date: 08/13/2014
Code: P0446
Explanation: EVAP System Vent Control Circuit
Date: 08/13/2014
Code: P0401
Explanation: "EGR ""A"" Flow Insufficient Detected"
Thank you
Code: P0305
Date: 08/13/2014
Code: P1404
Date: 08/13/2014
Code: P0404
Date: 08/13/2014
Code: P0341
Date: 08/13/2014
Code: P0446
Date: 08/13/2014
Code: P0401
Thank you
Last edited by artimeus; Aug 13, 2014 at 9:31 AM. Reason: Corrected the thread title
Regarding the P0341 code. I started seeing code P0341 repetitively on our 1998 Lumina. I would reset the codes but it would come back after a few minutes. At or near the same time, I was experiencing occasional dead battery problems. I installed a new battery and reset the code. The code did not re-appear for 3 months until an interior light was left on over an extended period without driving the vehicle. I jump started the car and found the P0341 code started appearing again. I charged the battery and reset the code, drove the car for 50 miles with no new codes. I just had the car pass California's smog inspection with flying colors. My conclusion: Make sure you have a properly working electrical charging system and a good battery before throwing parts at the car based on any codes reported by the PCM alone.
GBousley
Feb 20, 2014 10:09 AM
OraxThay
Jan 15, 2014 7:35 PM
mps2220
Jan 2, 2014 1:13 PM
