Platform: A-, G-, & W-body
vats bypass help
Old Nov 16, 2010 | 8:46 PM
rickywashere's Avatar
Default vats bypass help
ok i have a 98 lumina thought i had a fuel pump go bad cause it will start for a sec then die .. changed that same thing i can take the air intake off and slowly add gas and the car runs fine also i noticed that if i turn my key off it . and back on it starts right back up for like one sec every time . i have read till my eyes hurt and the best thing i can come up with is its the vats not letting the injectors work or cutting power to the pump .. i took a meter and read my key and i'm getting 1.47 with my meter set to 20k now what resistors value do need to bypass it ...
thanks
Old Nov 16, 2010 | 9:12 PM
MDTAHOE's Avatar
Professional Mechanic
1.47k
Old Nov 16, 2010 | 9:47 PM
THANKS for the fast reply also when i do the bypass will the reg key start the car or will i need a remote starter for it
Old Nov 17, 2010 | 6:41 AM
MDTAHOE's Avatar
It will start with key
Old Nov 17, 2010 | 8:48 AM
well just got done with the bypass same thing /// any ideas on what to try next ?
Old Nov 17, 2010 | 3:28 PM
just a update got a code reader threw back a code for the crank position sensor erased that it fired right up and is running like a top now
cameo89
Mar 30, 2011 5:09 PM
sara145
Jun 10, 2010 12:21 PM
