2008 Chevy Equinox wont start used meter reader it gives a code of 0P627 help
Old Jul 6, 2020 | 2:17 PM
KatRay2010's Avatar
Default 2008 Chevy Equinox wont start used meter reader it gives a code of 0P627 help
My 2008 Chevy Equinox will start but not turn over it just clicks. I put the meter reader on it and it gave me a code 0P627 says something about the fuel pump harness. Can anyone give me some direction???
Old Jul 6, 2020 | 2:27 PM
the code sets when the pcm detects the fuel pump circuit is open. either the pump is bad or the wiring is open/high resistance. the first step is to check the fuse pump fuse in the underhood fuse box. if its blown replace it. if it continues to blow now or at a later date...either the wiring or pump is shorted.
if the fuse is good. check for power at the fuel pump connector. disconnect it and it should have battery voltage for 2 seconds after the key is turned to run.
Old Jul 6, 2020 | 3:25 PM
KatRay2010's Avatar
It was in fact the fuel pump thank you for your help.
Geremy Tyne
May 13, 2020 9:49 AM
Mgeever
May 31, 2019 7:09 PM
Deanise78
Jul 10, 2015 1:32 AM
Equinox08
Mar 25, 2012 8:25 AM
mmiller
Nov 2, 2011 2:23 PM
