Looking for help
Looking for help
96 chevy suburban when turned off a fan will kick on and off there has been a few times it killed my battery by doing this I know that chevy did this to get moisture out of the evap or something like that but I don't know why it would go until my battery dies any one with any suggestions
I don't remember I just remember that a fan is suppose to kick on to remove moisture in the evap canister I do believe is what I found out when I looked up why a fan turns on for a few seconds then turns off when the suburbans ignition is off
there was an afterblow function that turns the blower motor fan on to remove moisture from the evaporator. the purpose is to stop bacterial/mold growth on the evaporator fins in hot climates. I thought it was only for model years in the 2000 or newer, never seen it in a 96. You can check with a scan tool. Go into the hvac or bcm modules with a full function scan tool and see if you can find "afterblow".
