Low oil pressure light 04 suburban z71
Old Jun 4, 2020 | 9:06 PM
Dammitbobbie's Avatar
Default Low oil pressure light 04 suburban z71
Just purchased 2004 suburban z71 with 150k miles. Clean engine- fully detailed prior to purchase. Test drive was excellent, nothing out of the ordinary. Drive home also completely normal. Later that night, drove for 30 minutes-20 minutes in oil pressure guage creeps up past 80, truck runs normally. Shut it off let it cool, everything is fine. 2 days later take it out to run errands. Engine on/ off for 3 hours at multiple stops- everything good. Take it on the highway for 10 minutes, low oil pressure light comes on. Now any time the engine gets heated and is driven for 20 minutes or more on the highway the light comes on once the truck comes down to idle. Sensor has been replaced, full oil/ filter change with Mobil 1 has been done. Still won't build pressure. Engine did shut down 1/8 mile from home, after cooling for 10 minutes started right up. Thoughts?
Old Jun 5, 2020 | 7:44 AM
Try a mechanical oil pressure gauge to see if you are getting an accurate reading from your gauge. Hopefully it is a problem with the gauge and not the engine.
kbella
Jun 8, 2017 3:07 PM
Hobbsie1
Site Feedback
May 25, 2016 9:19 PM
cisco190
Dec 8, 2014 10:37 PM
Peacher57
Sep 30, 2014 11:50 PM
