Tire and wheel size question
Old Dec 2, 2023 | 8:42 PM
JasoD's Avatar
Default Tire and wheel size question
I have a 2021 Chevy 2500 came factory with 275/65/20s gong to change to my spare tire size which is 275/70/18. Any issue with speedometer or anything else. Thanks
Old Dec 2, 2023 | 10:38 PM
Please read the bright red text at the top of the page. Thanks.
Old Dec 2, 2023 | 10:43 PM
ABS, traction control, steering, shifting, speedo/odo, fuel economy, acceleration ... all will be affected.
It's generally recommended to stay within 3% of the OEM size.
Old Dec 3, 2023 | 6:41 AM
JasoD's Avatar
Thanks. I have read that before about the 3% tire size change. On your chart you had put 270/70/18. My spare tire is 275/70/18 which puts it at 2.69%.
Old Dec 3, 2023 | 8:01 AM
Welcome to the forum.
Old Dec 3, 2023 | 11:42 AM
JasoD's Avatar
Thank you
Old Dec 6, 2023 | 3:34 PM
Originally Posted by johanbrandon
Upgrading from factory 275/65/20 tires to a spare tire size of 275/70/18 on a 2021 Chevy 2500 may result in a slightly taller tire.
No, it won't.
275/70 is a smaller by 1 inch.
Speedometer reading will 2.6% higher than actual speed
Old Dec 6, 2023 | 3:39 PM
My math indicates that the new spare would be 0.2" taller which would probably be inconsequential in the speedometer reading.
Edit: another problem besides speedometer reading with tires of different ODs is that it puts more wear and tear on the differential.
Old Dec 6, 2023 | 3:56 PM
Originally Posted by 73shark
My math indicates
Show your math.
275mm wide tire x 65% profile = 179 mm height (7 inches) or 14" (top + bottom) + 20" wheel = 34 inches total height
275mm wide tire x 70% profile = 193 mm height (7.6 inches) or 15" + 18" wheel = 33 inches total height
Old Dec 6, 2023 | 4:56 PM
You are correct. I miswrote the OEM tire size at 275/60 instead of 275/65. That would make a difference both in speedometer reading and wear and tear on both differentials.
Hunsberger68
Oct 2, 2017 10:22 PM
