1990 Chevy G20 Clunk
Hello,
I recently changed the transmission fluid and filter on my G20. Since then I have a clunk noise coming from whats sounds like the middle of the van. It only happens when I'm at low speeds and I start to accelerate or stop. Basically, the jerking moments when starting and stopping at stop signs and such. Once it gets going there's no noise at all. When I changed the fluid I removed the cross bar(?) that goes under the transmission in order to get the pan off. Then reinstalled it by jacking it up into place. I couldn't get it up by hand. It was too heavy with the transmission and other weight. Anyway, the transmission shifts fine and the van seems to ride fine, but the noise is really annoying. Obviously, something isn't right. Any ideas? I hope I didn't screw anything up when changing the fluid.
Thanks,
Dan
Thanks,
Dan
Greetings Dan, welcome to the Forum.
It sure sounds like you missed putting the Transmission Support (crossbar) back properly. Check all the Bolts to the Frame and Transmission again. You might have someone else take a look as well. Possibly IF there is more than one placement/adjustment that can be used, consider a relocation to allow good clearances between the transmission/body.
-Dan
berekhhnd
November 24th, 2016 3:07 PM
vanman2
November 17th, 2013 10:40 AM
