1998 gmc high idle
Old Jan 4, 2020 | 5:52 PM
Dollars78's Avatar
Default 1998 gmc high idle
It's a vortec 454. I've replaced iacv maf tps map and all intake gaskets. There are no vacuum leaks. I put the new iacv on and it idles down so low it would die. Replaced the iacv again and it idles high again (around 2500 rpms) I went back to the iacv that makes it idle low and manually adjusted the throttle so it will run. It runs fine like this but I know it isnt right. As far a codes go it showed the map then the maf. Now the only code I get is "iacv unresponsive" which is because the one I am using now is stuck but it is the one that works. Does anybody have any suggestions? Thank you.
Old Jan 4, 2020 | 6:13 PM
kevinkpk's Avatar
Did you check for any plenum air intake leaks?
Old Jan 4, 2020 | 6:22 PM
Dollars78's Avatar
I did and replaced to gaskets anyway. Checked all the upper intake for cracks and cleaned it as well.
Old Jan 4, 2020 | 7:31 PM
oilcanhenry's Avatar
I AC might not get proper voltage or a wiring issue.
RJK
Mar 4, 2021 4:22 PM
Lloyd O Bentzoni
Sep 24, 2018 7:02 AM
garegin
Jul 14, 2014 6:41 PM
tbone3703
Astro
Jan 1, 2011 12:31 PM
mimaheu
Aug 19, 2008 4:33 PM
