305TBI Crate Engine Swap Runs Poorly
Old Aug 4, 2021 | 6:39 PM
chinsky's Avatar
Default 305TBI Crate Engine Swap Runs Poorly
I recently swapped the engine in my 1991 Chevy K1500 Scottsdale. It was a direct replacement with a remanufactured GM 305 TBI. The new motor runs, but with a few new problems that I think are linked to emissions, fuel pressure or timing. Looking for experienced opinions on what might solve the problems.
The problems that I am experiencing include
1.) a lack of power
2.) stumbling/hesitation at ~2300rpm
3.) occasional power surge when pedal is pressed, leading to a service engine code 43 (ESC malfunction/ knock sensor).
My timing is set at TDC. I have also tried to advance it 4 degrees. Still haven't done a fuel pressure check.
Here are the items which I replaced during the engine swap:
  • Engine (block with assembled heads),
    • New block assembled
    • Heads assembled
      • valves adjusted according to recommendations
  • Cooling
    • Radiator
    • thermostat
    • temp sender
  • Spark
    • Distributor + cap
    • coil pack
    • new plugs and wires 10k miles ago
  • Emissions
    • EGR
    • TPS
    • MAP Sensor
  • Fuel
    • Fuel Filter
Does anybody have any thoughts on why this motor is running poorly?
Old Aug 4, 2021 | 8:31 PM
kevinkpk's Avatar
1.) a lack of power
    • Heads assembled
  • Cooling
    • Radiator
    • thermostat
    • temp sender
  • Spark
    • Distributor + cap
    • coil pack
  • Emissions
    • EGR
    • TPS
    • MAP Sensor
  • Fuel
    • Fuel Filter
Does this have a tps?
Old Aug 5, 2021 | 10:46 AM
chinsky's Avatar
Yes. I replaced the TPS. No change.
steve242002
Jul 28, 2021 7:14 AM
QBert
May 5, 2021 10:00 PM
Gregory Agee
Mar 1, 2014 5:26 PM
wmiller1337
Jun 26, 2011 1:07 PM
suzuki-guy
Apr 27, 2009 9:37 PM
