77 Chevy c20 picup electrical problems help please
Hello
I have a 77 chevy c20 pickup that has some electrical problems
when you turn the key to the on position the dash lights come on, the turn signal green lights come on, if you pull the light switch out the dash lights go out the turn signal lights go dim, if you turn on right or left turn signals they blink and the other side blinks dimly.
oh the turn signal lights stay on lights on or off
I have replaced the light switch, replaced the printed circuit board on the dash panel, replace and added anther ground wire from the engine block to the firewall, I have looked for any broken or burnt wires and have not found any. Is there a ground wire to the fuse block?? if so what color is that wire?
there is no black wire
also the heater blower motor stays on when you turn the key on to
I put in a new switch for this to.
I know there has to be something I am overlooking
anyone else run across this??
Bill
Bill
mikedanielsut
February 6th, 2012 4:51 PM
Sebastianofcm
January 31st, 2012 12:28 AM
For Sale: 1971 gmc / chevy 2500 truck c20
pjsshell
November 10th, 2011 12:56 PM
1968c20
11
October 3rd, 2011 5:57 AM
