85 K10 ignition cylinder replacement
Old Mar 15, 2021 | 2:22 PM
Paula O'Rourke's Avatar
Default 85 K10 ignition cylinder replacement
Trying to replace the ignition on my 85 K10-- removed steering wheel but getting stuck when I hit this piece! No idea how to get it off. Thoughts?
Y shape
Old Mar 16, 2021 | 10:42 PM
oilcanhenry's Avatar
You'll need an adaptable puller. You can likely rent one from an auto parts store. But you have more pulling to do.
This vid wot be exactly whet you have but its close enough to see what else you'll need to do,
Old Mar 21, 2021 | 7:05 PM
Thanks so much! Got everything off and replaced the ignition (truck started right up) so success.
New problem: putting the steering wheel parts all back on. I can't get the locking plate back on because I think the splines aren't lining up with the splines on the shaft. (Should've marked it with a sharpie to start, but here I am now.) Any ideas for this problem?
Old Mar 25, 2021 | 6:48 PM
There MAY be a gap in the splines. Look for that or other wear marks. Let me know if you find any of this.
jameszr2
Oct 19, 2018 10:54 AM
nauticstar87
Mar 25, 2015 8:55 PM
MellyMel2186@hotmail.com
Oct 20, 2014 11:19 AM
Arborist1212
Jan 12, 2013 8:39 AM
wahtulookin
Feb 10, 2012 6:22 PM
