95 Lumina LS Van Front End Clunk
Old Jun 24, 2011 | 12:32 AM
lumina38's Avatar
Default 95 Lumina LS Van Front End Clunk
Hi all,
I had a pretty bad clunk from the front end of my '95 Lumina LS 3.8L van. 75k original miles. It would clunk just about all the time.
I just replaced the struts and strut mounts with new ones, but I still get a clunk sometimes (less often) from the front right. It happens when I apply the brakes, when turning, going up driveways, etc.
I don't believe I installed the stuff wrong. The spring went into its groove correctly.
I replaced the inner sway bar bushings and outer tie rods as well. The outer sway bar bushings still need to be replaced, but I doubt that's whats causing this heavy clunk. All parts were original from '95. I did the pads and rotors a while ago too.
What could this be? Engine mounts? The control arm bushings and ball joints look good to me.
Thanks
timabrams
Uplander
Dec 7, 2011 4:11 PM
Mfree
Jul 27, 2011 3:58 PM
fsh4fun05
May 1, 2009 11:22 AM
Gypsy
Apr 8, 2008 9:56 PM
