98 Chevy Prism - Gauge Fuse Blowing
Old Sep 21, 2012 | 2:02 AM
garrettj94's Avatar
Default 98 Chevy Prism - Gauge Fuse Blowing
I'm having this problem with my 98 prism. Most of the time when i shift from P to R, my gauge fuse will blow, and my A/C and my gauges turn off. I don't know why its doing this, but any help will be accepted!
If you need more info let me know and ill find it out. Thanks!
Old Sep 21, 2012 | 11:23 AM
Look for and damaged wires that may touch any of linkage for the shift mechanism. Look under dash as well as at the transmission. What is the label on the fuse? Do your back up lights work with the blown fuse? More information is really needed!
Old Sep 21, 2012 | 12:52 PM
garrettj94's Avatar
The label is 10a gauge fuse. Where do I look for damaged wires? the only wires i can find are next to the fuse box. by backup lights, do you mean my regular headlights?
Old Sep 22, 2012 | 7:53 AM
I am talking about any wires that touch the shifter linkage. Either under the hood or under dash that may touch the linkage when it is moved causing a short. You should also look at the backup light circuit for a short.
02PrismLSI
Oct 29, 2013 7:28 AM
10tfeni
Jun 16, 2008 1:03 AM
clwill65
Astro
May 15, 2008 4:53 PM
fastblueheeler
Aug 12, 2006 2:53 AM
Fuel
Mar 24, 2006 12:42 PM
