99 Chevy 3500 won't start
Old Aug 14, 2014 | 9:23 PM
roap6677's Avatar
Default 99 Chevy 3500 won't start
Have a 99 3500 and have been dealing with it for a month not starting. It had low fuel pressure so we changed out the fuel pump. Fuel pressure is at its spec but still will not start. Unplugged and cleaned the mass air flow sensor. Replaced cam sensor, the distributor cap and rotor, still nothing and today we changed the computer and still no luck. It will crank over, stay on for one second the shut off. Sprayed carb cleaner and it will stay on with hesitation. Slowly wanting to give up on this truck. Any thoughts?
Old Aug 14, 2014 | 10:59 PM
Rednucleus's Avatar
distributor module?
Old Aug 15, 2014 | 12:29 PM
roap6677's Avatar
distributor module?
Not sure where that is located at. The onlymodule I seen was the ignition module, and that was mounted on the coil bracket. The only sensor in the distributor area was the camshaft sensor which was replaced also.
Old Aug 15, 2014 | 10:28 PM
Rednucleus's Avatar
sorry - meant ignition module. My 93 has it in the dizzy. Change that yet?
Old Aug 18, 2014 | 6:25 PM
roap6677's Avatar
Already checked that, it was unplugged truck would not start with carb or starting fluid, plugged it back in truck started with starting fluid and immediately died
TCL_2000_ChevyXprs3500
16
Aug 16, 2016 12:16 AM
ZChevyAK
Nov 13, 2015 6:45 PM
rdkeisman
Oct 21, 2013 2:07 PM
chris 419
May 18, 2013 10:29 PM
bracca
Jul 12, 2009 6:14 PM
