Australian built 75' chevy c20 pickup
Old Jul 18, 2013 | 6:24 AM
Aussiec20's Avatar
Default Australian built 75' chevy c20 pickup
So I thought id put up a thread of my new addition and to keep a log of all the work ill be doing to it over the next few years.
Here's some pics of it....
It's running a 454 bbc with a twin throttle body 'gas reaserch' setup.
I have posted my truck on an Aussie v8 forum and learnt abit about these Australian built American chevrolet pick ups.
These are the build plates
A guy on the forum, found this info on it.
I've just finished a first draft of an article for Truck Jungle (for Mark Oaster) on these Aussie build Chevy trucks.
This is Dandenong assembly, PSN (J487620) places it as 7/75 assembly which the ADR plate confirms.
Paint (1821) is Glacier White, also confirmed by the Dulux paint code of 13134. 439 paint line is Dulux Acrylic Enamel, which is an enamel that could be touched up with Acrylic.
63V is Saddle coloured embossed vinyl.
The model code of C20903 is the 3720kg GVW (C20) cab chassis. The number after the model code on the identification plate (599078) is something I am not 100% certain on. Could you possibly check and see if this is the number used as the chassis number, or if the AJ487620 is used. Note that these are the ONLY GMH assembled thing that I know of where the PSN is used as the "chassis number" on the ADR plate, A is the ADR revision and J487620 is the PSN (end of the VIN).
The VIN (8CT235) decodes as follows:
8 is the division ie 8=GMH.
C is the chassis type, C=conventional.
T is the engine description, T=292 6cyl.
2 is the series, 2=20 (ie C20).
3 is the body type, 3=cab chassis.
5 is the model year, pretty certain same as Holdens ie 1975 model year is 9/74 to 8/75.
It would have originally had a Mexican 292ci 6cyl and 4spd box There wasn't too many options available when yours was built. The only options were a HD stabiliser shaft (sway bar), LSD, fuel tank guard and a spare tyre and tube.
Lastly, can I use some of the ID tag photos in the article? I can cover up a digit or two here and there if you like.
So this is my truck and hope you like it and follow my build...
Josh
Old Jul 24, 2013 | 12:33 PM
SWHouston's Avatar
That's one helluva Kangaroo Clipper you got on the front of it, wouldn't be surprised if you had to use Load Range "E's" just for it
miss_niki_star
Aug 7, 2014 1:31 AM
Chevrolet Forum News
Dec 19, 2012 1:28 PM
t.mcginley.jr
Sep 7, 2011 2:17 PM
LaveenChevyRider
Aug 15, 2010 4:09 PM
