Need steering column expertise
Old Jan 26, 2019 | 6:51 PM
Kazoocruiser's Avatar
From: Currently the Candian Gander is wintering over in New York.
Default Need steering column expertise
This should be an easy fix but maybe GM is making me go back to school. I have two issues with the column.
The truck is a 1981 C-10, automatic, with an even older replacement non-tilt steering column.
1. Earlier this year I had the steering wheel off to replace the turn-signal switch. At that time I noticed the rod that is supposed to engage the lock-plate was not extending when I would turn the key off. I couldn't figure out how to get the push rod from the lock mechanism to seat into the block that extends the steering wheel lock-rod. I can see the key-geared rod move back and forth when I turn the key, but IDK what I am overlooking. How is the pusher rod supposed to be secured to the block?
2. I had the wheel off again today to try to fix a lock-cylinder that won't reverse to turn on the accessory position for the radio. It was binding, but even though now it is lubricated, and seems to work freely, I am not getting any radio operation. The radio works fine on the run position. Maybe that is an electrical switch adjustment . . .
Thanks in advance for any assistance.
Last edited by Kazoocruiser; Jan 26, 2019 at 7:17 PM. Reason: double post / want to delete, but cannot find
Old Jan 27, 2019 | 5:45 PM
Nvrmind, turned out the actuator (steering wheel lock) rod was not engaging a gear rack correctly that the lock cylinder rotates. It was off a tooth. Now the steering wheel doesn't move when I key-off and engage " lock."
Had to take the electrical part of the ignition switch off, to get the rod that drives it so I could access the back of the collar. Once I had everything back together, I was able to find a place in the adjustment which allows the radio to work in the accessory position, and also start the truck when the key is rotated the other way.
