Parasitic Draw On Battery
Old Apr 19, 2021 | 10:20 PM
Rayzen's Avatar
Default Parasitic Draw On Battery
I have an old 1984 V-8 Chevy van (G30) underneath a Lindy class C RV. The problem is that there is something sucking my battery at the rate of 3 amps and I can't find the source of that drain. I have done the usual method of trying to find such a drain: hooking my meter in series with the battery's negative post and chassis ground, then pulling the fuses, one at a time, hoping to see the meter drop to zero, but I've pulled every single one of them and the meter continues to show 3 amps flowing. The battery is brand new. The Haines manual states that there is only one fuse block, which is under the dashboard, next to the driver's left knee. If there is another fuse block somewhere, I don't know where that is.
Obviously, I have made sure that there are no lights on anywhere inside & outside, the key is off, all doors are shut, all fans and other motors turned off, etc., so there should be zero current being drawn from that battery. I can only conclude that there must be some kind of short to ground somewhere, but then I'm certainly no auto electrician, so I am probably missing something.
What can I do next to find the problem?
In trying to find the problem, I have looked in my Haines 1968-1992 Automotive Repair Manual, but I see that the fuse block picture does not match mine, so I'm now going to see if I can find something online. If anyone would have a good link, I would sure appreciate seeing it.
However, of more concern than finding the right fuse block picture, I would really appreciate hearing any tips as to just how I should proceed with troubleshooting the system to find the source of the current drain.
All of the external lights (headlights, turn signals, backup lights, brake lights, emergency flashers, parking lights) work fine, as well as the windshield wipers. The engine starts and runs fine.
Any help would be very much appreciated.
Old Apr 29, 2021 | 5:15 PM
Rayzen's Avatar
I found the problem. It was a bad alternator; I unplugged it and there was no drain. Is this forum still active? --not a single reply in ten days.
Old Apr 29, 2021 | 6:34 PM
kevinkpk's Avatar
Yes, it is active. You stated in your OP you put your meter in series, testing it would put it in parallel, no big deal. There has been alot of post regarding the same issue you have/had. Perhaps you could have looked in the archives, I don't either , I just post. Glad you found it.
Old Apr 29, 2021 | 6:40 PM
kevinkpk's Avatar
Sorry if if you put your meter in series, yes. I'd just check the voltage drop on the battery
TrainerBBD
Jan 21, 2024 7:03 PM
staskus
Aug 22, 2021 7:25 AM
Newsom09
Dec 29, 2020 11:46 AM
epadilla
Jan 30, 2014 12:33 PM
jfonod
Dec 28, 2007 5:12 PM
