Starting Issues and where to start with troubleshooting
Old Oct 23, 2018 | 9:07 PM
BigBoom's Avatar
Default Starting Issues and where to start with troubleshooting
I have an 89 6.2 Chevy G30 (Short Bus converted to an RV) with about 120K on it and recently it has decided to not crank. The engine spins and spins but never actually starts or even sputters. I took it on a 3,000 mile trip without any issues and after parking it at the house for about 2 weeks it started, ran for 30 seconds and died. My thought is fuel pump, fuse or relay. Thoughts? At this point I'm not even sure where to locate the relay or the fuse for the pump. Any help would be greatly appreciated.
Side note that might help - I filled the tank FULL of diesel before parking it back at the house so I would be ready for the next trip.
Old Oct 24, 2018 | 10:13 AM
geo1's Avatar
So,lift pump not running?test for power to it,at pump with it disconnected
Old Oct 24, 2018 | 10:18 AM
Inside the fuse panel cover there is a diagram of all the fuses and relays located inside that box.
Old Oct 24, 2018 | 12:01 PM
Oldcat's Avatar
This is in no way meant to degrade you or insult your intelligence. However I must say this..... You stated that you filled the tank and then it ran for about 30 seconds and died. Now to me that sounds like the right amount of time for it to run until it ingested some contaminated fuel or the wrong fuel. (Gasoline by mistake?)
Old Oct 24, 2018 | 12:09 PM
geo1's Avatar
Possible, but I was thinking,the lift pump died on last run,they will run without it,some have anyway,depends on the strength of injector pump,so for the test,can't remember,test for power to lift pump after wts light goes out?
Old Oct 24, 2018 | 1:26 PM
BigBoom's Avatar
So just to make sure I understand here, the lift pump is the one inside the tank correct? So just pull the positive wire and test with a test light to make sure I have power coming through the relay?
Old Oct 24, 2018 | 1:27 PM
BigBoom's Avatar
I'm not sure if there is another fuse panel other than the one under the dash but I don't have a cover on mine. I've got about 8 fuses and a wide long rectangular relay. Is that the fuse pump relay?
Old Oct 24, 2018 | 1:29 PM
BigBoom's Avatar
I totally agree but I siphoned some fuel out of the tank it is definitely diesel. It could be contaminated diesel although this happened one other time (a few months back) and when I filled it back up (about 1/5 of a tank) I'm sure it was diesel. How do I know if it's just contaminated? Should I go the electrical troubleshooting route and revisit if that doesn't go anywhere?
Old Oct 24, 2018 | 1:32 PM
BigBoom's Avatar
What is the WTS? Is there an in-line pump in addition to the lift pump and the injector pump?
geo1's Avatar
Lift pump on frame rail,no?
