S-10 & Blazer 1982-2005
03 s-10 missfire.
Old Dec 22, 2008 | 12:21 AM
dirtydime03's Avatar
Default 03 s-10 missfire.
My s-10 has recently been misfiring badly, before anything is said it has new ignition,timing set,injectors,head rebuilt. Sensor's are good, fuel psi is good no DTC's. It was only misfiring under a load and then it got real bad and killed the injectors, with those replaced it was still there and now its horrible and still no DTC's. I found this TSB https://chevroletforum.com/recalls-a...604030/TSB.htm[/align][/align]I'm wondering if that's the culprit to my problem. anybody else had this happen to them?[/align]
Old Dec 22, 2008 | 4:46 PM
Default RE: 03 s-10 missfire.
Anyone have a clue?
Old Dec 24, 2008 | 4:18 PM
johndb's Avatar
Re-check your timing first,as youv'e put a lot of parts on. Also what is the repair for that TSB? ,you may have already replaced the part(s).
Old Dec 25, 2008 | 8:28 AM
I'm not sure what the repair is, I found it here and it didn't have anything to hint at repairing it.
Old Dec 26, 2008 | 3:53 PM
johndb's Avatar
Possible it's just bad gas?
Old Dec 26, 2008 | 8:08 PM
its been through a fewtanks since it has started.
ke5eme
Apr 10, 2013 10:18 PM
Buck2ooth
Jan 3, 2010 8:53 PM
vroomvroomchevy
Jan 24, 2009 4:45 PM
vermena
Apr 11, 2007 3:31 AM
vermena
Apr 9, 2007 10:46 PM
