1999 blazer fuel strap
Hello all I am trying to remove my fuel tank so that I can change a bad fuel pump, on a 99 4dr 4x4.I have the front strap loose and the rear strap the bolt just turns. it has backed out abit but it just seems like it doesnt want to come out. and yes im turning the right way.has anybody had this problem and how do i fix it. next step is sawzall and hope for the best. thanks for the info.
RE: 1999 blazer fuel strap
usually what happens is the holder for the nut rusts and breaks so the nut in the frame just spins.3 options. cut the strap and buy a new one, cut the strap and drill a hole in the 2 ends of the strap and bolt in a piece, or cut thebolt if you can and put a new bolt in
well I got my fuel strap fixed, now i go to put everything back together and i found that the part on the front of the tank is broke, I assume it is a fuel return, it is yellow, and has a fuel hose that goes to it and itcomes out of thetank. My question is is this replacable? what is the proper name and how do i replace it?
Bill's Dad
June 22nd, 2010 5:21 PM
