S-10 & Blazer 1982-2005
1999 blazer won't start
Old Jan 6, 2022 | 2:27 PM
davealexder's Avatar
Default 1999 blazer won't start
one day blazer was hard to start {took several cranks } before it started. next day would not start @ all . acted as if it wasn't getting fuel , few days later tried again and it acted as if the battery was low {crank then dash lights go out only clicks} went to charge battery only to find battery was full.I turned key to acc.dash lights turned on then they shut off, turned on again then shut off.vehicle will now not do anything, try to start and nothing no dash lights no click nothing.. please help Dave
Old Jan 6, 2022 | 3:07 PM
Welcome from Florida. Check your battery cable connections at both ends also for looseness and corrosion. Also make sure the alternator is charging properly.
Old Jan 6, 2022 | 7:00 PM
will do thanks for in help
Old Mar 10, 2022 | 1:16 AM
VannihrMorningstar's Avatar
Default Crank but no start
That's a wide range of possible issues, I'll list all I've encountered.
Ignition switch control module under distributer cap faulty, injector o-rings worn, bad battery connections (did a big three upgrade to fix), bad fuel filter (or fuel pump), low battery (if it's dead long enough, it'll never take a full charge), bad ignition coil (or bad ground connection to, some models develope a loose connection) and bad ignition switch (located in cab above steering column).
Best bet, is start with cheapest issue, and work your way up.
How this helps.
Old May 23, 2022 | 4:49 PM
Did you ever solve the issue?
shewee52
Aug 27, 2017 2:44 AM
odeho19
Feb 25, 2015 11:04 AM
jimmydriver
Jan 19, 2015 10:19 AM
Chevyforlife8
Feb 26, 2013 7:31 AM
truesmack
Jan 27, 2008 2:05 PM
