S-10 & Blazer 1982-2005
1999 S10 Trailer lights
Old Aug 10, 2007 | 1:15 PM
dengo45's Avatar
Default 1999 S10 Trailer lights
I have a 99 S10, When I try to connect Trailer lights to the wiring harness and connect a trailer it will blow the turn signal fuses. The fuses are under the hood. I heard that thier is a connector under the hood to connect the harness is this true.
Old Aug 11, 2007 | 7:34 AM
golfer's Avatar
Default RE: 1999 S10 Trailer lights
I've never heard of any connector under the hood for hooking up trailer wiring.
It's not clear as to what kind of wiring on the truck ... is it hard wired into the truck harness or is it an adapter type that simply plugs into the trucks wire harness ? Is it a four pin flat plug ?
Likely there is a short in the trailer's wiring since you only blow fuses when the trailer is hooked up.
Check all wires for bare copper or places where a wire could be pinched and touching metal on the trailer or your tow vehicle's chassis/frame. Remove the bulbs from the trailer's lights and with a multimeter check to make sure there isn't continuity to ground ( the trailer's frame )on the green , yellow , brown wires.If that is ok, then calculate the amp load your trailer is pulling. Most vehicles are equipped to handle only standard lighting on trailers; one turn/brake signal on each side and one marker light on each front corner. Check your vehicle owner’s manual for specific power ratings. If it is not a short, a pinched wire, and your vehicle is rated to supply the necessary number of amps (power), then consult a professional.
The basic 4 pinwire colors on the trailerare :
- right stop/turn ( green )
- left stop/turn ( yellow )
- tail,license,clearance marker ( brown )
- ground ( white )
OliOliUmphry
Dec 31, 2019 10:06 AM
intheknow
Jul 24, 2014 10:38 AM
cookj
Jul 25, 2013 12:21 PM
DOBERDEWD
Dec 11, 2011 11:35 PM
skdevore
Aug 26, 2009 10:18 PM
