S-10 & Blazer 1982-2005
2.8 Dying out at red light.
Old Jul 26, 2009 | 1:07 AM
Kalispellbob's Avatar
Default 2.8 Dying out at red light.
I have done a complete tune up. wires, plugs, cap, rotor. fuel filter sperk plugs, but when i get it up to running tempeture it stalls out at red lights does any body have any ideas its driving me crazy. its a carburated engine.
Old Jul 26, 2009 | 5:43 AM
mudmaniac's Avatar
Ride of the Month
May 2009
Was it originally carburated or was that a mod?
Old Jul 26, 2009 | 8:37 AM
Old Jul 27, 2009 | 9:58 AM
far2grumpy's Avatar
Hey Bob ... does it die when you gas-it to take off?
Or, just start idling lower and then dies?
Is it manual or A/T?
Does it die if in neutral.
Do you have a vacuum gauge? Just wondering if you could monitor the vacuum at idle as the engine warms up?
Old Jul 27, 2009 | 4:23 PM
it dies when i am idling at red light or stop sign. it is a manual 4 speed. A friend of mine that is a mechanic came over house last night and looked at it for me. He found a rubber hose that goes to PVC valve had a hole in it. He changed it for me and it seems to be running ok. I will post back later after i drive it a little. I was looking for bad vacum hoses but i guess my eyes are not as good as they used to be Thanx Guys. Bob
Old Jul 27, 2009 | 6:41 PM
suzuki-guy's Avatar
Spray ether around the hoses and intake if it idles high you have a vacuum leak.
Old Jul 27, 2009 | 9:55 PM
old dog's Avatar
Default 2.8
my 85 2.8 auto i had to replace about 25 feet of vacuum hose they were all soft . they would fall off at the wrong time .
Old Jul 29, 2009 | 3:13 PM
Didnt find anymore vacum leaks but it happened again today. I was pulling out of walmart. I was shifting through gears and all of a sudden it felt like it was starving for fuel. It lasted about 10 seconds and i pumped on gas a couple of times nothing happened then it finally kicked in again. The whole truck didnt shut off just the fuel it seemed like. I was thinking maybe changing fuel pump on engine what do you think. Bob
Old Jul 29, 2009 | 8:47 PM
far2grumpy's Avatar
Bob ... I hate carburetor's and mechanical fuel pumps ... you've had other posts with this truck and I don't remember - have you changed the carb?
Up until this last episode the complaint has been power loss while truck is stopped. I'm thinking there could be a sticky needle-valve or float. Something that keeps the bowl from filling and staying full.
The fuel pump, or debris in the fuel line, could also cause a problem.
Your instincts are probably good regarding the fuel pump ... I actually have a pressure gauge for one of those old critters -- seems like they only put out 5 pounds or so.
genesisi30
Dec 23, 2013 1:49 PM
Disco69
Jul 3, 2009 8:22 AM
Big D
Mar 29, 2008 10:49 AM
biglg
Jan 25, 2008 7:44 PM
