S-10 & Blazer 1982-2005
2000 Blazer ~ Ran out of Gas ~ Problems
Old Jul 10, 2012 | 2:40 PM
JonMount's Avatar
Angry 2000 Blazer ~ Ran out of Gas ~ Problems
I ran my blazer out of gas about 2 weeks ago. I notice the low fuel light was on when I pulled into work. By the time I left work I had forgotten about it until I had already gotten on the freeway. I figured I could make it until my exit, I figured wrong. It sputtered a couple times and died. I walked back to the nearest gas station and purchased a can and 2 gallons of gas. I put the 2 gallons in it and it wouldn't start. I thought maybe because the angle the truck was sitting off the side of the road the fuel wasnt reaching the pump. I walked back to the gas station and got 2 more gallons. It still wouldn't start. I replaced the filter and still no start.
Someone told me that the pump may have burnt up running dry. I replaced the pump and strainer this morning. When I turn the key on the pressure goes to 62lbs, after I crank the motor it drops to about 57lbs. I sprayed a little fuel in the throttle body but it did't start on that either. I checked the plugs for fire. There is fire but it was a dull orange and the plugs looked pretty ratty so I went ahead and replaced the plugs. Still nothing.
Any tips?
Thanks,
Jon
Old Jul 10, 2012 | 3:42 PM
kevinkpk's Avatar
Plugs looked like sootie, or what is ratty? The gas in the tank keeps the pump cool. Never run your tank that low. The orange spark should be blue. Is there a code?
Old Jul 10, 2012 | 3:56 PM
JonMount's Avatar
Sootie pretty well describes it. No codes are coming up on the scanner.
Old Jul 10, 2012 | 4:00 PM
kevinkpk's Avatar
Are all of them that way? If so, I'd replace the ignition module.
Old Jul 10, 2012 | 5:41 PM
JonMount's Avatar
All of the plugs looked like it had been running a lil rich. I replaced the plugs. Now I'm getting bright blue/white spark. It still will not start. I tried spraying starting fluid down the throttle body and it still won't start.
Old Jul 10, 2012 | 7:54 PM
kevinkpk's Avatar
Not a dumb ?, but one I have to ask. You had an orange spark before, now it looks good. What has changed from orange to blue, and is the plug wires correct?
Old Jul 10, 2012 | 9:08 PM
JonMount's Avatar
I had a dull orange spark with the old plugs. With the new plugs I have bright blue spark. The plug wires look okay. The firing order is the same as it has been for the last year or so. It had been running okay. It doesn't have a ton of power but it runs smooth. It has 235000 miles on it, so I never hot rod it.
Now that it don't want to hit on starting fluid in the throttle body I don't know what to think. I'm getting a lil irritated with it.
Old Jul 10, 2012 | 9:42 PM
kevinkpk's Avatar
Plugs don't have anything to do with that. The spark delivered to them is what works.
Old Jul 10, 2012 | 11:47 PM
JonMount's Avatar
Fouled plugs wouldn't cause weak spark? Where should I go from here? Maybe something else caused it to die and the low fuel light being on didn't have anything to do with it? It had been running fine and the check engine light had not been on.
Old Jul 11, 2012 | 9:12 AM
RacerX's Avatar
disconnect the battery for 10 mnutes and then reconnect and retry to start it. additionally, you may have to check the fuel level and the position of the strainer on the fuel pump.
