S-10 & Blazer 1982-2005
2000 Blazer Headlights
Old Sep 18, 2007 | 8:12 PM
ajvp's Avatar
Default 2000 Blazer Headlights
About ready to use the sledge...
Just got (2 weeks ago) a 2000 Blazer 4dr 4x4 for the wife. Everything seemed fine until she noticed a problem with the headlights... So here is what it does... The DRL turns on all 4 lights (hi and low). When you turn on the headlight switch, all 4 come on (with no highbeam indicator on inside.) When the lights are off and you flash the lights (with the multifunction switch) you get all 4 (and the highbeam indicator inside works.) Using the multifunction switch does nothing except when the lights are off. The Automatic lights turn on all 4. I noticed that a ground was replaced/installed on the pass. side connected to the lowbeam blue wire. (disconnecting this new gnd wire = no headlights at all) I thought maybe someone had installed some sort of Quad mod but I don't see any diodes b/t low & highbeams (found that info on one of the forums.)
I've replaced:
headlight relay
DRL relay
headlight switch
multifunction (turn signal) switch
I have another headlight harness (incase I missed something in the headlight wiring) coming from s10Warehouse.
I kinda remember seeing somewhere, someone said that it might be a problem in the BCM. Does anyone buy that?
Anyone have any ideas (besides taking it to the dealer.)
Thanks
AJ
fols4u
Sep 5, 2013 11:54 AM
David_lee1993
Nov 1, 2012 11:06 PM
Howlander
Dec 5, 2008 4:14 PM
atvfury
Feb 1, 2008 8:04 PM
